AC 180 WON'T SHUTDOWN
SCOTTINBROOKSGA
09-10-2005 04:18:44
MY AC 180 DIESEL SPUTTERED AND THEN WOULD NOT SHUTDOWN WITH THE FUEL SHUTOFF. TEMP WAS NORMAL, FUEL WAS GETTING LOW BUT PRIMARY FILTER WAS FULL. FINALLY SHUTDOWN AFTER TEN MINUTES.ANY HELP APPRECIATED
BobMo
09-11-2005 05:37:10
 Re: AC 180 WON'T SHUTDOWN in reply to SCOTTINBROOKSGA, 09-10-2005 04:18:44
Your unit won't run without fuel so its not being shut off period..... ..... .
big orange
09-10-2005 06:54:57
Did you check the shut off arm on the pump to make sure it was full off.Sometimes the cable slips or if it's like a 185 a clamp on the cable comes loose then the cable flexs instead of going to full off.
