oval cut hole in hood of WD
sad
09-09-2005 18:59:24
This would be where the muffler would come through. I understand that the original muffler was made by Nelson,now owned by Fleetguard.My question is was the original muffler oval?
John (MO)
09-12-2005 10:37:28
 Re: oval cut hole in hood of WD in reply to sad, 09-09-2005 18:59:24
I have to agree that this is not a factory cut hole. All WD's and WD45's had round mufflers. AC did not use oval mufflers until sometime in the 60's. The early D series tractors also had round mufflers. It's no trick at all to cut any shape hole you want in sheet metal and someone has done that to the tractors you are talking about here.
John (C-IL)
09-09-2005 19:50:21
Nope, the WD/WD45 muffler holes were always round. Someone probably used a D17 muffler.
sad
09-09-2005 20:02:32
 Re: oval cut hole in hood of WD in reply to John (C-IL), 09-09-2005 19:50:21
So did they always cut/stamp out oval holes in the hood also? Im positive the hole is factory.
Sid
09-10-2005 00:52:46
 Re: oval cut hole in hood of WD in reply to sad, 09-09-2005 20:02:32
I have never seen a WD or a WD forty five with a oval hole in the hood.
Linus
09-10-2005 02:54:28
 Re: oval cut hole in hood of WD in reply to Sid, 09-10-2005 00:52:46
All of the original dealers books I have for the WD or WD45 only show a round muffler.
Utah Jim
09-10-2005 15:45:55
 Re: oval cut hole in hood of WD in reply to Linus, 09-10-2005 02:54:28
I have a 49 WD with an oval hole in hood. The tractor was painted red by someone and then left out in a field for about 30 years. Very faded now. Still runs very strong.
sad
09-10-2005 17:54:17
 Re: oval cut hole in hood of WD in reply to Utah Jim, 09-10-2005 15:45:55
Utah Jim,I knew that there was more out there with the oval cut in the hood.Mine is a 1952.Thanks Dan
chalmersbob
09-10-2005 19:59:32
 Re: oval cut hole in hood of WD in reply to sad, 09-10-2005 17:54:17
i have a b with a oval hole in it. easist way to remove the under hood muffler. your hoods probably came off of a wc, that had a oval muffler under the hood, and was installed on a wd. definetely not factory. BOB
Dean
09-10-2005 22:35:57
 Re: oval cut hole in hood of WD in reply to chalmersbob, 09-10-2005 19:59:32
Styled WCs did have an oval muffler but it was entirely under the hood. Only the round pipe extended through a small round hole in the hood.
Dean
