where is inspection hole for timing mark on 1939 w
peter hendricks
09-08-2005 18:17:26
I can get it to run perfect when magneto is 45degrees from where it is suposed to be, I just want it in the right spot so it looks right and then i can put the bolts where there suposed to be instead of the way they are thanks in advance,p.s. idont no wich hole on the bell housing is the timing hole this is a allis 1939 wc
gene (missouri)
09-08-2005 20:36:42
 Re: where is inspection hole for timing mark on 19 in reply to peter hendrickson, 09-08-2005 18:17:26
Inspection plate is on the bottom of the bellhousing. The timing marks are on the back side of the flywheel.
Use the search function at the top of this page and search timing WC. There are a number of posts describing this function.
Gene
