Wire Gauge
Vince H
09-08-2005 08:53:25
I am going to be replacing the wiring on my AC B and need to know what gauge wire to use. The last time the wiring was repaired I know the correct wire was not used. I am going to be still running the original 6v system.
steve(ill)
09-08-2005 16:38:17
 Re: Wire Gauge in reply to Vince H, 09-08-2005 08:53:25
12 gauge wire will handle 20 amps so that is overkill for the generator charging system. lights, coil , etc i like to use 16 gauge. 18 is o.k., but 16 is a little heavier duty for tractors.--- battery cables should be BIG. local auto stores will have 2 or 4 gauge, those are for 12 volt systems. you should go 0 or maybe 2.
