Wd block
dave
06-11-1998 18:56:10
is the block for a wd the same as a wd45 ?
or is there more changed than just bore and
stroke. thanks
mm
07-05-1998 22:48:20
 Re: wd block in reply to dave, 06-11-1998 18:56:10
: is the block for a wd the same as a wd45 ?
: or is there more changed than just bore and
: stroke. thanks
Hi The wd is powered by a W-201 engine. It has a 4" bore and stoke. Naturally, it displaces 201 ci. The WD-45 is powered by a W-226 it has 4" bore and a 4.5" stroke, 226 ci. The 45 came from 45hp on the belt. The best 226 you can get is the G-226. It is the one with the side cover cast in the block. It is rated at 67hp. at the flywheel. It can be found on E, E-3 gleaner combines. In a D-17 tractor it is rated at 53 hp on the PTO. Overbore 4.125" sleeves are available for all these engines.
keith
06-12-1998 13:08:06
there is two differant blocks from what i've been told. there is a panel that bolts on the side of the wc, wd blocks, and some of the wd45's don't have that bolt on panel.
