WD exhaust manifold needed
ron bond
09-07-2005 11:14:44
A neighbour has a WD with an Allis loader I can buy, but it neds an exhaust manifold (GAS).Does anybody have one and how much, I am in Ontario-near Peterborough. Also, how much is a WD with loader worth - hasn't run in 7 years?
Zonie
09-09-2005 03:04:17
 Re: WD exhaust manifold needed in reply to ron bond, 09-07-2005 11:14:44
if this is a WD tractor, is it a WD-45 Diesel? I think that"s the only engine that had the exhaust manifold on the opposite side from the intake.
Scott-IA
09-07-2005 20:25:34
Once you get the tractor and manifold, leave the wrench in the tool box, and grab a good sharp chisel. With just a few whacks those nuts cut right off, don't buggar threads, and come right off. Just make sure your chisel has a good edge and corner (rounded corners will not cut straight down the nut). Also, cut straight at the engine in the direction of the stud....not sideways into the stud.
Good luck
David in Mo
09-07-2005 13:42:50
Click on the Store forum at left under "marketplace". They have new ones for about 140 bucks and the gasket set is 12 bucks or so. The biggest challenge will be to take the nuts off the studs..... ...if there is anything left..... .search this forum under "studs" to see how some guys handle it.
ron bond
09-07-2005 14:49:39
 Re: WD exhaust manifold needed in reply to David in Mo, 09-07-2005 13:42:50
THANKS FOR THE TIP ON THE EXHAUST MANIFOLD. i DON'T HAVE THE TRACTOR HOME YET, BUT IT SEEMED TO ME THAT THE INTAKE WAS ON THE RIGHT SIDE OF THE ENGINE, AND THE EXHAUST ON THE LEFT. THE PICTURE LOOKS AS THOUGH THEY ARE COMBINED. AM I MISTAKEN.
THE EXHAUST MANIFOLD ON THE TRACTOR I LOOKED AT WAS OFF-BUT THE CARB AND INTAKE WERE ON THE OTHER SIDE.
ALSO, WHATS A WD WITH A ALLIS LOADER WORTH THAT NEEDS AN EXHAUST MANIFOLD?
Aaron SEIA
09-08-2005 07:35:24
 Re: WD exhaust manifold needed in reply to ron bond, 09-07-2005 14:49:39
A WD has a combined intake/exhaust manifold. If the engine you looked at had them on opposite sides, then it's either not a WD, or it's been re-powered with something not Allis Chalmers.
Aaron SEIA
gene (Missouri)
09-07-2005 16:20:24
What's a non running WD with loader worth. Not much. Last week, Jefferson City, Mo. Sunday paper was a runing WD for $750.00.
The manifold on the WD series tractor is on the left side of the tractor. The intake and exhaust are combined into one (piece) manifold.
Use the search function at the top of this page. Search for WD prices.
Parts get expensive in a hurry. Me, I would purchase a running WD. Central Missouri, $1000- range will get you a WD in very good condition.
Gene
