WD-45 alternator problems
Rowdy Yates
09-05-2005 18:05:09
I've installed a GM "1 wire" with a wire from the batt terminal to the battery, a wire from the #1 terminal to the switched side of the on/off switch, and a wire from the #2 terminal to the switch on the starter. Two days later my bettery is dead. What did I do wrong? And what should I do to fix the problem?
Dale
P.S. It won't charge with just the wire on the batt terminal to the battery.
