Help on E-gleaner and W D 45
imorgan
09-03-2005 18:59:59
Could anyone tellthe diff. between the E-gleaner and W. D. engine in detail and what could be done to the head , to get more power. milling etc. May be other thing also. THANKS.
UUSEE
09-04-2005 04:31:56
 Re: Help on E-gleaner and W D 45 in reply to imorgan, 09-03-2005 18:59:59
Milling the head will do nothing,on Allis motors the combustion chamber is in the bore and the top of the piston.You can go up to 4.125 bore with a sleeve and piston set.You also can then use a 4.125 piston from a WC or WD,the wrist pin is lower in the piston there by moving the piston further up.More compression,a LOT MORE.A Lot of little things,minor rework of the carb,governor spring from a 170,larger valves,bore the block to put in custom sleeves and pistons,stroke it.Money and the will to possibly destroy a antique are your limiting factors.
