Hurst
09-04-2005 08:47:32
Re: 170 diesel clutch in reply to banjo, 09-03-2005 20:55:56
For tools to split, you can get it apart without and overhead hoist. At our farm, we use an old A frame and chain hoist, but most people don't have a good A frame around anymore. The easiest thing I can think of is to put wood blocks under the torque tube (and have a jack lifting it up some so you should, if the tractor could flex much, have a little arch it in, that way the wood will have pressure on it when you pull it apart. Also, put wood wedges in the front on the axle so it doesnt tip. Now, use a good roling floor jack under the front part (make sure you put it on something that can hold quite a bit of weight, not sure if an oil pan on those are that strong). Then with the help of some friends, roll the front and the jack back. Keep an eye on the jack also, don't let it slip out from under you. I would also chalk the wheels in both directions in the rear before starting and in the front once pulled apart. About finding a clutch place, look up clutch and also try joint in the yellow pages. Here is a link to the results from the yellowpages.com in OK, but all these places seem to be in NE or E Ok. Hope you find a good place, it is definatively worth a little drive because it will save you. If you can't find anyplace, atleast let a machine shop resurface your flywheel, then trade all the other parts in for a good rebuilt produce (including the pressure plate, because the springs will need replacing). Hope you find a solution and keep posting if you've got any questions. Also, try the Unofficial Allis Chalmers board, there is a guy that has a shop in OK. I think his name on the forum is Okieboy, but not for sure, I bet if you post there and ask for someone in OK, he should be able to help you out. Good luck Hurst
