firing order
jhk's wd
09-01-2005 12:21:21
I am doing a complete tune up and I need to know the firing order and the number 1 piston to start I hav e 54 wd. 4 cyl. with a gen, and distributor. I also need to know where the condenser, is. Obviously I am not the most knowlegable with this older equipment. Thanks guys. jhk's wd
CHALMERSBOB
09-01-2005 19:21:56
 Re: firing order in reply to jhk's wd, 09-01-2005 12:21:21
1243 FIRING ORDER. #1 PISTON CLOSEST TO THE RADIATOR (FRONT). THE CONDENSER IS IN THE DIST, RELEASE THE SNAPS, REMOVE THE CAP AND ROTOR THEN THE WATERPROOF COVER AND THE POINTS AND CONDENSER WILL BE VISIBLE. CONDENSER IS THE SILVER ROUND TUBE WITH A WIRE COMING OUT 1 END. GOOD LUCK BOB
