AC-Wheel Bearing Problem
J. Cash
08-29-2005 18:24:25
I noticed after cutting the grass/pasture the other day, that the right rear tire was leaning inward. I had noticed just prior to parking the tractor it sounded sort of like a rubbing sound. I purchased the tractor from the previous owner of our home, there is no manual and such. Does anyone know what steps to take to remove the wheel axil and such..any information is greatly appreciated..
steve(ill)
08-29-2005 19:22:23
 Re: AC-Wheel Bearing Problem in reply to J. Cash, 08-29-2005 18:24:25
if it is a small B tractor, there are a couple things to check. the axle shaft mounts in two big bearing and very seldom fails.--- the 20 inch diameter cast steel hub presses onto the shaft splines. the 2 inch nut on the end of the axle shaft keeps the hub tight. if the tractor runs with the nut loose for a few hours, the splines will wear and not fit the hub. if it just cam loose, retighten it now. --- next, the rim sets over the cast hub and held on with 4 cam locks. see if the rim is wobbling on the hub. may need to redo or tighten the 4 cam locks. this is also used on the C tractor.--- now if you got a larger tractor, thats another story.
Joe M(GA)
08-29-2005 18:25:53
The model or a picture would help us help you
J.Cash
08-30-2005 04:45:35
 Re: AC-Wheel Bearing Problem in reply to Joe M(GA), 08-29-2005 18:25:53
Posted a pic in the "help identify" section of the photo gallary
J.Cash
08-30-2005 04:40:21
Joe, I have uploaded two pics of the tractor.. One is a picture of the wheel up close and the other is of the full tractor.. My husband found a number on a sticker that had: Allis Chambers B then B118698..
Texas Denny
08-30-2005 07:03:24
 Re: AC-Wheel Bearing Problem in reply to J.Cash, 08-30-2005 04:40:21
Where did you upload them to? I've checked every place on this site and only found the original picture in "Help Identify".
