d-14
jk
08-29-2005 17:19:42
i'm going to look at a d14 in a few days. what do i need to look for? what were there weaknesses? if it runs good/looks goos and has good rubber id it worth the $2000 price tag? what model loader will fit it? thanks
John (MO)
08-30-2005 05:35:34
 Re: d-14 in reply to jk, 08-29-2005 17:19:42
You need to make sure the transmission hasn't been abused and that the tractor does not jump out of gear. First check the brakes and make sure they work ok, then drive it down hill in each gear with the throttle pretty well open. After it builds up speed quickly close the throttle. If the transmission has been abused by years of poor shifting, it will pop out of gear and you will be free wheeling. NOTE: This can be a wild ride if you didn't check the brakes or they don't work! As I said, do this in each of the 4 gears. If it jumps out of gear, you have transmission problems and they can be a high dollar fix. $2000 is a darn good price for a good running D-14 with a good transmission, but you'll want to investigate what you'll spend fixing the transmission if you uncover a problem there. As for loaders you can use any of the trip bucket loader that were used on AC's from the WD up through the D-17. AC made several, #9, #90, 100, 140, 150, 170 and a 400 which will need the front pump because it is fully hydraulic. There are also loaders made by Paulson and Worksaver and others that will work. About all you'll need to do is maybe drill a couple new holes in the loader mounting frame to make them work from one AC to another.
jk
09-04-2005 17:49:57
 Re: d-14 in reply to John (MO), 08-30-2005 05:35:34
the guy who has the 14 has a loader on a 15 that will work. he said to make him an offer but i didn't know what it was worth. its the good old trip bucket loader. did any of those loaders (except the 400 maybee) has power up and down (2 way cycelenders) or were they just one way?
Texas Denny
08-29-2005 21:07:26
If everything works, it is worth all of $2K. Can't anser the loader question.
