Need help on a 200 Allis
Chris from Illi
08-28-2005 15:44:25
I've got a hydraulic hose leaking that goes to the hydraulic couplers, it is under the fuel tank, Is there a way to get this changed without removing the tank? To make matters worse it has a cab. I have always been a Case guy so I don't know much about Allis Chalmers at all. Any help would be appreciated. Thanks.
Joe(TX)
08-29-2005 05:33:38
 Re: Need help on a 200 Allis in reply to Chris from Illinois, 08-28-2005 15:44:25
Remove the platform bolts in front of the fuel tank, loosen the bolts on the instument panel tht tie it to the platform and the front platform bolts on the torque tube. You should be able to lift the rear of the platform enough to work on the hoses. You will have to disconnet some of the linkage from the console.
