Not Sure What Model Number AC I Own
John Quillen
08-28-2005 14:02:10
I bought an Allis-Chalmers Tractor and don"t know if I have a Model B or C. Someone put a decal on the Tractor indicating it"s a "B". The serial number is C3563. Does the letter "C" preceding the serial number indicate that that particulary serial number is a "Model C"? Thank You!
bw in mo
08-28-2005 18:13:14
 Re: Not Sure What Model Number AC I Own in reply to John Quillen , 08-28-2005 14:02:10
The C infront of sn# means it should be a C, I think someone has put a B front & steering on it .
John Quillen
08-28-2005 18:18:34
 Re: Not Sure What Model Number AC I Own in reply to bw in mo, 08-28-2005 18:13:14
Thanks BW: It certainly appears that way.
John
steve(ill)
08-28-2005 16:26:26
the B and C share the same motor, radiator, transmission and bevel gear housing. the B is less than 60 inches wide rear wheel outside to outside. it is a 1 bottom plow tractor. the C is closer to 6 ft wide as it has longer alxe shafts, 6 inches on each side.--- the serial number is by the transmission shift lever as you said. The B is a wide front end tractor. the steering gear box below the gas tank has an arm that points straight down. the rod goes to the left front axle king pin.--- THE C can be narrow of wide front end. gear box below gas tank has an arm that points straight up. rod goes to a second box below the radiator and line under neith steers the tractor.
John Quillen
08-28-2005 17:17:04
 Re: Not Sure What Model Number AC I Own in reply to steve(ill), 08-28-2005 16:26:26
Thanks for the info Steve:
I measured the width of the Tractor in the rear outside to outside wheel and it was just about 72". The gear box arm point down and the rod goes to the left front axle king pin. From your info it appears that I have a model B front end and a model C rear end!!! Do you know if the letter "C" preceding the serial number has any significance? Thanks again.
John
