WD 45 low power
Truth seeker
08-26-2005 17:37:34
Hi!
The problems with the tractor first started back in 2002. The tractor had just been bought in good running condition, and we had been using it for a week or two. However it was being driven over to do bushoging it was running along fine when all off a sudden it lost power, and barely made it up the next light hill, got it back home and tried to pull some equipment. It wouldn't pull. it would just try to stall and wouldn't even spin the tire that had little traction on it. We tried tinkering with it. But had to deal with other more important things, ('cause our vehicals were breaking down at the same time.)
Anyhow, to make a long story short we found that the gasoline from the stations was bad. and now I want to get the tractor running and working once again.
I checked the commpression and all of the cylinders had 120psi and we've gone over the carb a couple of times.
Thanks for any and all help.
wdtom
08-26-2005 18:57:46
 Re: WD 45 low power in reply to Truth seeker, 08-26-2005 17:37:34
Vacume leak? Gas cap not venting? Timming off? Weak ignition? Low gas flow due to clogged tank outlet or filter? Governor not kicking in right?
Sho-Man1
08-28-2005 13:23:23
 Re: WD 45 low power in reply to wdtom, 08-26-2005 18:57:46
Have you checked the air cleaner for dirty oil or mice? Our D17 had the same symptoms. Cleaned gunk out of the oil bath air cleaner and she started up quicker than it had in ten years and had the old snap back. The old gal had been setting more now that the new tractor showed up.
