Misfiring problem on a B - cold tappet settings ?
Grennie (UK)
08-26-2005 07:52:38
After engine warms up certain cyclinders start misfiring. This normally occures after the engine has been running for 10 minutes. I have changed the head gasket as I suspected it was water getting in to a cylinder originally.
The book says the tappets should be set at .010" hot but it is not always easy to do that. Could it be that when certain push rods are getting hot they are preventing the valves from fully closing (hence its missing on that cylinder)? I have now set the tappets at .020" cold but should I increase this to eliminate the possibility of 'expanding' push rods ?
Final point .. when the engine has cooled down and is started again it fires on all 4 cylinders.
Jerry Rivas
08-28-2005 09:24:37
 Re: Misfiring problem on a B - cold tappet setting in reply to Grennie (UK), 08-26-2005 07:52:38
Yo Buddy. You might as well start by finding a coil tester. If it were mine, I'd change plugs, cap, rotor, wires, points and condensor. If that dont cure it. Sell it. But whatever you do, dont run the valves real loose. They will be noisy and you'll lose a good bit of yer 22 pony power.
Jerry from East Iowa
08-26-2005 09:42:22
Hi, Grennie
To answer your question about what the cold setting should be, take your hot setting and add .002 to it. (ie. .010 hot is .012 cold, .015 hot is .017, and so on)That will hit the mark almost every time.I do agree with the other guys when they say your problem is more than likely ignition.Questions please e-mail [email protected]
Thanks,
:) Jerry
Jerry's Tractor Repair Holy Cross, Iowa
John T
08-26-2005 08:15:54
Is it ALWAYS the same cylinders that drop out?? If so and its not the valve problem, you may wanna check the cap n rotor n plugs n plug wires to those cylinders !!!
If you remove the plug wire back maybe 1/8 to 1/4 away from the missing cylinders plug n she fires then, its a faulty fouling plug. A faulty condensor or a coil can act up once hot also, but that shouldnt always be on certain particular cylinders only!!
John T in Indiana, retired electrical engineer
Jerry Coulter
08-26-2005 08:15:03
Don't run your valves too loose. This sounds like an ignition problem. Are you using Champion spark plugs? They are yesterday's premium plug, but they don't perform well these days. You could be having a heat failure in the coil or condensor. Pull a plug wire off when the tractor is running and compare the spark strength while cold, then warm.
Grennie (UK)
09-07-2005 03:23:23
 Re: Misfiring problem on a B - cold tappet setting in reply to Jerry Coulter, 08-26-2005 08:15:03
Changing the condenser fixed the problem. Used it last weekend and it worked fine. I even drove it the 8 miles to the event and back again.
Many thanks for advice given.
Grennie (UK)
08-26-2005 08:40:36
Thanks guys .. I'll wait till it stops raining then test the spark. What I have already done is to remove the leads off the plugs while it is running (using insulated gloves) to determine which cylinder is missing but I havn't checked the spark off the lead .. good thinking 99.
