B Question...
usedtobeiowadave
08-25-2005 08:27:31
Went to start my B last night. Don't always check the oil, but I did, thankfully...not a drop. Turns out the steering linkeage that connects the left front tire to the right (Newer model square wide front end) has been rubbing against the front slope of the oil pan and it finally wore a hole. The pan's getting brazed as I write this. One, I'm thankful I learned a lesson the easy way for once. Two, anybody else had this happen? What should I look at as to why the linkeage was rubbing like that?
old
08-25-2005 09:31:38
 Re: B Question... in reply to usedtobeiowadave, 08-25-2005 08:27:31
Just a guess here but I'd jack it up and check for a lot of play on the pivot pin for the front axle. It maybe letting it sort of pivot back to the oil pan in which case the pin/bushing would need fixed/replaces.
