AC forklift
Scrib
08-24-2005 22:16:34
I recently bought an old AC forklift.It turns out that the engine is shot. Rod brg. turned which ruined the crank and one rod. The eng. is a Buda 153. I bought a used crankshaft which needed to be turned down .020 as the original one was already at .020 and .030. The rod I used was from an old 262 Buda that was scrap. It seemed to fit perfectly. The only manual I could get for this engine was an IT Cockshutt 30 manual. I had the valve guides knurled and bought new valves. The exhaust valves are too tight and I don't have a reamer. I was wondering if there's a substitute tool, ie: grinding compound and an old valve stem? and possibly an electric drill?? I ground the seats which turned out ok, 45 degrees. The seats are approximately 1/16" in width, which looks good. Any ideas about reaming the guides??
dej(JED)
08-26-2005 04:58:34
 Re: AC forklift in reply to Scrib, 08-24-2005 22:16:34
I have an AC D15 forklift. I got an engine out of a regular forklift at a bone yard near me in Western, Pa. He had several others if you need one.
mhlon
01-25-2006 18:47:57
 Re: AC forklift in reply to dej(JED), 08-26-2005 04:58:34
I need a carriage for an allis chalmers 500 612 forklift Do you where any are?
Scrib
08-27-2005 18:11:00
Just got the AC running about half an hour ago. Wouldn't you know it? Had to change the thermostat that worked BEFORE I overhauled the engine, but of course stuck and required replacement. Otherwise, no leaks no problem, 30lbs oil pressure, should run another 30 years. Thanks for your help. I'll maybe post a picture after we get it painted and looking like new.
Scrib
08-26-2005 07:39:43
Got my guides reamed yesterday, and head installed. Engine should be installed today. Should run like a Rolex! I'll post later with results.
Glen in TX
08-24-2005 22:27:10
A valve guide reamer or put in some of the bronze liners. These places have tools and liners. Link and Link
Scrib
08-24-2005 22:52:14
 Re: AC forklift in reply to Glen in TX, 08-24-2005 22:27:10
Thanks, Good advice, as I've spent quite a bit on this already. Hate to screw it up now!
Glen in TX
08-25-2005 09:22:03
 Re: AC forklift in reply to Scrib, 08-24-2005 22:52:14
I don't have any listing for that engine. You might try these: thecarburetorshop dot com or zenithfuelsystems dot com or find someone that has a parts book listing for the E60 engine.
