WD pinion bearing adjustment
Guyzoo
08-24-2005 13:38:25
Hi guys, I removed the bevel pinion shaft out of my 1952 WD and tried to tighten the bearing a little bit since it is a little sloppy. My problem is that there is a kind of pin that seems to lock the big nut in place so I can,t turn it in any direction and I don't see any ways to remove that pin. (The transmission is the first type one)
THANKS FOR ALL YOUR HELP AND PATIENCE
