Engine Rebuild A C 226 HELP
las
08-23-2005 18:07:11
I am would like to known what to do with this engine to get more power without useing up me life safings. I do not known if it has the 4.25 over bore or not it is a egleaner engine. I use it for pulling, it runs great maybe I should leave it be? THANK FOR ANY INPUT.
John (MO)
08-24-2005 06:46:13
 Re: Engine Rebuild A C 226 HELP in reply to las, 08-23-2005 18:07:11
I think the life savings thing is your limiting factor here. If you are pulling a tractor with 226 original cubes, you may be pulling against people who have spent more than somepeoples life saving on their engine and now have over 400 cubes to work with. You can`t make as much HP from 226 cubes as you can from 400 cubes. All it takes is money, as the song goes.
Don Dittmar
08-24-2005 05:25:56
If the 226 engine is out of a combine, I would leave it alone. These engines usally had more HP anyway. I do believe there was a d17 diesel made into a corn picker and this d17 diesel had the turbo off the d19 on it. Allis reccommended that you did not convert this back to a tractor
Hurst
08-25-2005 10:12:01
 Re: Engine Rebuild A C 226 HELP in reply to Don Dittmar, 08-24-2005 05:25:56
It was a 262 gas that was dropped into a d17 diesel for the corn picker. This was done from the factory on a very small number of tractors. I believe that it also distributed the power in different places so that you would not overpower the rearend??? Not sure, but for a puller, it could work if you do some work on the rear end maybe? Hope this helps.
Hurst
