WD45 Problem
Sweat Eck
08-22-2005 11:24:53
I'm replacing the brakes and drum on a WD45. I got
the retaining pin out with a sawsall and torch and
that was tough. Now I can't get the drum off the
axle. Tried heat and a puller and a big hammer, no
luck. I also can't separate the final drive from
the axle housing to remove the axle shaft. My
manual says to "bump" it. I've more then bumped
and no movement. Also can't get the wheel axle
shaft "bumped" out to replace the seal. I removed
the snap ring inside near the bull gear, but no
luck moving anything there either. I'm kind of
stuck like my parts. Can anyone point me in the right direction. Usually I can get through anything after a while but this stuff has me stumped and I don't want to damage any parts.
Thank you.
Tramway Guy
08-23-2005 07:49:47
 Re: WD45 Problem in reply to Sweat Eck, 08-22-2005 11:24:53
I gave up trying to pull one off and decided to take it off in pieces. Used an arc welder as a cutting device and finally got a crack in the hub, that finally did the trick. Cutting torch doesn't work, because it is cast material of some kind.
Texas Denny
08-22-2005 14:26:57
According to my IT manual, there is a snap ring on the brake drum and it must be on the side toward the wheel. If you have removed the snap ring and it still won't budge, you may have to pull the large shaft out so you can put it in a press.
Regarding the wheel axel shaft. I have removed the shims and put it back together and tightened up the the screw. Sometimes this movement on tightening will move the race enough that it will come apart (pushing it more together first). I remember having to be pretty brutal getting that axel out of my D-17. After removing all of the shims and washers, screw the bolt in to being less than a 0.1" from being tight. Then strike the bolt squarely with a heavy hammer. You might ruin the bolt but it is a cheap replacement. I've done this a few times and never required a new bolt.
Sweat Eck
08-23-2005 18:41:19
 Re: WD45 Problem in reply to Texas Denny, 08-22-2005 14:26:57
Thanks guys for the ideas, I'll keep trying to
get it apart. Can't let it beat me.
