wd 45 questions
JackT
08-19-2005 18:58:03
I have a couple of semi-trivia questions about my WD 45.
First, on the snap couplers that attach to the lift arms there is a round sleeve that looks like it would accept a horizontal shaft about 1-1/4" in diameter. What was that for?
Second, on the rear step plate there is a slot, about 1/2" wide and 1-1/2" deep at the rear edge. What was that for?
Thanks
JMS/MN
08-20-2005 06:35:58
 Re: wd 45 questions in reply to JackT, 08-19-2005 18:58:03
The other posters are right regarding the lift arm latches, especially the danger of using the crossbar on the WD45. However, the 'Snap Coupler' does not refer to the lift latches- it refers to the bell-shaped housing under the tractor that the drawbar latches into. It made attaching mounted implements very easy, allowing for a wider angle of approach when backing up to the implement. Competitive tractors with a 3ph were more difficult to align with the implements to attach them.
Eldon (WA)
08-19-2005 20:51:20
The lift arm latches made for use with a stabilizer bar were meant for the D series. If a bar is used on a WD/WD45 it can be a very dangerous situation because of the large pto guard and the fact that you mount the tractor from the rear..... .heard it can be a leg breaker. I have a set of heavy duty latches that were put on a WD45 and the loops had been milled off, so I assume AC did that for use with WD/WD45 and removed them for liability reasons.
Den/southern Illinois
08-19-2005 19:08:26
There is a round bar that goes from arm to arm on the lift latches...make them more stable. Mostly used on the D 17s and up.
The slot on the rear step plat was made to accept the older style PTO covers that were atached to the PTO driven implement. Once you hooked up the implement, the shield which hinged in the middle would be straightened and the catch mechanism would slide into the slot...held there by a spring loaded latch. Hopes this makes sense...maybe you had to be there to see it if I did not describe it correctly. Den
