48 Rear Rotary Mower for Simplicity 9020/AC 720
gmurph
08-19-2005 09:28:26
I have a PowerMax 9020 and I am looking for a rear mower for it. I see that this model has an odd PTO and I don"t have the shaft, so I need a setup made for the tractor or an adapter to transition from the 1 Inch 15 spline to a standard 1 3/8 6. Can anyone help?
mowr
08-20-2005 19:54:17
 Re: 48 Rear Rotary Mower for Simplicity 9020/AC 72 in reply to gmurph, 08-19-2005 09:28:26
As you no doubt know, this is a category 0 tractor. That means not only the 3-point but the PTO as well. Category 0 PTO turns at 2,000 rpm so, of course, you'll need to find a category 0 mower with a category 0 PTO shaft to match your tractor PTO (and 3-point). You can imagine how far the pieces of blades and other things would fly if something designed to run at 540 or 1000 rpm was run at 2000. A good used Cat. 0 mower may be a little difficult to find but I suspect that any tractor dealer that sells name brand (JD, Kubota, AGCO, etc.) garden tractors would be able to get you a new one.
