carb to governor link A C B
joe in Mi
08-18-2005 19:25:57
I have a 1940 B in mid rebuild. I need to know how long the link between the governor rod and the carb should be. I've had it running but it doesn't seem to be right. Also I don't have the correct hand crank, could someone let me know at what angle the pin is compared to the handle. Thank you for any help.
Link Shadley
08-20-2005 07:40:41
 Re: carb to governor link A C B in reply to joe in Mi, 08-18-2005 19:25:57
third party image
My 1939 A/C B has a spring at the junction between the governor arm and the rod to the carb. The rod on the gov and the rod to the carb both have 'eyes' swedged and drilled, with a short light spring connecting them. However the I&T Shop Manual shows a 'hard' pin and eye connection. My rod from the carb to this point has a 15 degree bend up so the eyes would not line up to insert a separate pin. The other night, I shortened the spring and got another couple of hundred rpm out of the engine. I need to recheck it with a tach, but suspect I'll at least have more power. I'll try and insert a scanned image of page 29 of the #AC-11 manual.
Rod (NH)
08-19-2005 12:14:00
Hi Joe,
Here's the crank from my 1942 B:
third party image
I assume you are talking about the crank arm that attaches to the carburetor throttle shaft at one end and the governor linkage at the other. That part on my B measures about 1-5/8", hole center-to-center. I say about because it's hard to get a perfect measurement without carburetor removal. That's for a Zenith carburetor (#212845).
third party image Rod
Joe in MI
08-22-2005 16:44:58
 Re: carb to governor link A C B in reply to Rod (NH), 08-19-2005 12:14:00
I was at the tractor show in Oakly, Mi over the past weekend and looked at several B's most of them had the link that was bent up and towards the motor. Mine on the other hand seems to be almost straight. thanks for the pictures they are a real help.
