Belt pulley
Kelvin
08-18-2005 06:02:57
I'm looking for a belt pulley assembly for an A-C WD. The WD I just bought has just a plate so I'd need eveything. Where would be a good place to look for one. I'm located in southeastern Wis.
Thanks!
Bill(Wis)
08-19-2005 08:55:01
 Re: Belt pulley in reply to Kelvin, 08-18-2005 06:02:57
Kelvin: 715-673-4829. He has a lot of used Allis parts. Located S of Eau Claire. Incidentally, a WC pulley will work just as well. It was the same pulley.
JMS/MN
08-19-2005 08:24:22
Tey the flea market at a tractor show. AC show in Hutcvh, Mn had several vendors with them- from five to twenty dollars each for complete units. I expected them to be worth more.
Dave Grubb
08-18-2005 11:47:24
When you are ready to install the pulley be sure you have the right side of the tractor 6" or so higher than the left side. There is a lot of oil behind the plug you remove to insert the pulley drive through. Also the series of locating holes around the barrel of the drive are drilled at slightly different dimensions from the gear end of the drive. Lock the barrel in a hole that provides 1/8" in/out play between the pulley rim and the frame rail. Put a punch mark on the barrel and the frame for future reference on the correct location of the barrel.
old
08-18-2005 08:47:38
Where you at? I think I have one on my parts WD. E-mail is open by the way
Texas Denny
08-18-2005 08:17:27
Ebay or any tractor salvage yard. Someone may have one on this board. I have two that I am not using but I have three tractors that I may want them on so I'm already short one.
