WD-45 Belt Pully Drive
Paul D.
08-15-2005 04:15:15
Help! I can't figure out how to engage the large belt drive pulley on the right side of the tractor. I 've had several folks look at it to no avail. The manuals I have show how to take it apart and work on it but nothing on operating.
Any info would be greatly appreciated.
Durbo
JMS/MN
08-15-2005 11:55:05
 Re: WD-45 Belt Pully Drive in reply to Paul D., 08-15-2005 04:15:15
The details of using the pulley are in the operator manual. What Eldon mentions about using the proper hole is important- especially if the pulley is not original to the tractor. It was the dealer's pre-delivery job to mark the correct hole on the pulley sleeve to obtain proper backlash. Can't remember the exact figure, but I think the pulley should wiggle about 1/8 inch forward/back at the proper backlash. If it doesn't wiggle at all- major problems ahead.
Eldon (WA)
08-15-2005 07:36:51
Just to clear up a few things....the bearing housing of the pulley assembly has a series of dimples in a spiral pattern that the set screw should mate up with. To find the correct one, look for an index mark on the housing. This should align with a mark on the frame rail (unless the pulley isn't original to the tractor). This is to make sure that you have the proper backlash for the gears.....otherwise you will experience excessive noise or gear/bearing wear. If you remove the pulley assembly from the tractor, run the rear wheel up on a block or set on a sidehill to keep the lube from running out the hole.
Sid
08-15-2005 05:54:01
What Mike said,except the foot clutch operates the belt pulley. It has a lever by the foot clutch that will lock the foot clutch in the foward position to keep the pulley from operating. i strongly recomend you do not have the tractor running when putting the pulley on the tractor.
Mike /IA
08-15-2005 04:46:23
Above the belt pulley in the housing you will see a bolt with a jam nut, you need to back this bolt out enough to slide the belt pulley drive into the housing this will mesh the gears. Retighten the bolt in the groove in the belt drive and it will be engaged. There is not a lever or anything to engage or disengage the belt pulley.
alliewc
08-15-2005 18:37:22
 Re: WD-45 Belt Pully Drive in reply to Mike /IA, 08-15-2005 04:46:23
there was a after market set up for the belt pully quick engagement for the wc/wd/wd45 tractors. to engage the pully with the clutch in you just pulled the rod that was fastened to the steering colum out and locked the pully in gear. I have two tractors with this set up on them.
Paul D.
08-23-2005 19:12:18
 Re: WD-45 Belt Pully Drive in reply to alliewc, 08-15-2005 18:37:22
Gents,
Thank you for all your responses. This worked out for me.
Paul
