double acting cylinder hydraulics for WD45
George C. Schmi
08-14-2005 19:43:55
Is there a way to make the hydraulics on a WD45 work with a double acting hydraulic cylinder? I want to build a simple log splitter and would like to use the tractor hydraulics if possible. The existing WD45 hydraulic cyliner does not have enough stroke and I don't think the existing small diameter WD45 cyliners would exert adequate force for log splitting anyway.
Any thoughts or ideas.
George C. Schmidt
Jerry(mo)
08-15-2005 10:56:53
 Re: double acting cylinder hydraulics for WD45 in reply to George C. Schmidt, 08-14-2005 19:43:55
third party image
Your old WD45 Hyd pump is not putting out 3200psi
and I bet your lucky to get 2000psi out of the old girl. Any cylinder will work fine but the bigger the cylinder the slower it will be. I converted my WD45 over to double acting cylinders and it works great
Tramway Guy
08-15-2005 06:39:03
A simple way to get it to retract is to use one or more large springs to pull back a single-acting cylinder. Use the smallest bore cylinder that you can find, as long as it has a large enough rod that it doesn't bend and is rated for the 3200 PSI pressure.
JMS/MN
08-14-2005 19:55:20
You cannot use a regular (ie 2000 or so ) cylinder because the WD runs about 3200 pressure. If your tractor has a remote hookup, you can power a two-way cylinder with that, but you need to run the return oil line back into the resevoir. If you do not have the remote, there will be an unused port on the hydraulic valve that you can use to power the extra cylinder. Same port that your remote line would be hooked in to.
John (C-IL)
08-14-2005 19:47:43
You will have plenty of power with the small diameter cylinders because they are low volume high pressure. For that reason using a regular cylinder would be disappointing because it would be slow.
Your real chalenge is to find a way to get the cylinder to retract after you split the log with a single acting cylinder.
