oil filter
Jack Lillar
08-14-2005 17:15:40
I have a 1952 AC WD.The oil pressure is in the normal range when the tractor is running but when I changed the oil filter no oil ran out ofit and it appeared to be dry.The tractor sat for several weeks before the oil change,I'm wondering if in several weeks of setting with the filter setting upright that it would look dry. It does seem heavy.
Texas Denny
08-15-2005 09:20:19
 Re: oil filter in reply to Jack Lillar, 08-14-2005 17:15:40
Yes, the filter will drain into the pan when setting for a few days.
Ted Seifert
08-14-2005 17:33:46
There is no check valve to prevent drain back. IF you start your tractor and oil flows out of the vertical tube without a filter and you have normal pressure with the filter installed , you should be OK.
