AC 190 Questions
fencline
08-11-2005 18:46:36
Folks,
Afriend of mine is considering buying a 1967 Gasoline with 4 speed trans & hi/Lo shift. Are there any things to look out for on this model? Does it have a live PTO? If so how does it work.(how is it engaged etc.)Any info / thoughts would be appreciated.
Thanks,
Andy
old
08-11-2005 19:54:52
 Re: AC 190 Questions in reply to fencline, 08-11-2005 18:46:36
The live PTO work off the hi/low shifter or also known as power dierrect.
fencline
08-12-2005 04:56:15
 Re: AC 190 Questions in reply to old, 08-11-2005 19:54:52
Old,
Could you explain further?
Thanks,
Andy
Joe(TX)
08-12-2005 05:29:11
 Re: AC 190 Questions in reply to fencline, 08-12-2005 04:56:15
It depends on if it is a mechanicla or hydraulic pto. The mechanical has a levet on the left side rear of the platform. It engages a coupling in the lower gearcase to engage the pto. You have to use the engine clutch to start and stop the pto.
The hydraulic has a clutch in the bottom of the torque tube to start and stop the pto on the move. The lever is on the side of the right console. The engine clutch will also stop the pto. For live pto on both, you use the power director (high/low) on the console to start and stop the tractor movement.
