G burning oil
Matt Sheaffer
08-11-2005 13:57:23
Hello - I have a G that gets used quite regularly on our farm for seeding and cultivating. Over the last few weeks it started burning quite a bit of oil - constant smoke coming out of the exhaust. I changed the plugs - they were pretty fouled up - and had very little change. It continues to blow smoke, leading me to believe the problem is pre plug. Where should I start looking for the problem. Thanks in advance.
Dick L
08-11-2005 16:23:11
 Re: G burning oil in reply to Matt Sheaffer, 08-11-2005 13:57:23
Did you get it hot?? If the water gets low and you get it hot the G will start to smoke and burn oil. If that is what happened you can drop the pan, pull the pistons down out the bottom one at a time, put new rings on the pistons, put them back in and your ready to go. On the other hand if it is wore out, that is another thing, no quick fixes when they are wore out.
