Allis Engine and Heads - What do they fit
Dennis Moeller
08-08-2005 20:32:32
I have an Allis engine and some heads that have been stored in an old barn for many years. I need some help in identifying what tractor models they came from.
The engine has the numbers U3019-10 cast into the side of the block. Also under the large side valve lifter cover the numbers 6-24-37 appear. I believe it is a 4" bore. It has no provisions for a starter and the flywheel has no starter ring. The block has a freeze crack but the internals such as crank, rods, pistons, flywheel, clutch, etc appear to be in nice shape. In addition to the head on the above described engine, I have 3 other AC heads. One has the casting number AM2917-16 along with CL 101739. Another has U3001-16 (possibly-18) along with the numbers A171. The third has no cast no's what so ever, at least I can't find any so I guess I can't expect much help here unless someone can tell me where to look for the numbers. The heads all require a total rebuild, but don't appear cracked. Any help anyone can give in identifying these parts will be greatly appreciated. Also if anyone has any thoughts as to what this stuff might be worth, I'd welcome the input. Thanks in advance for any help
