WD or WD45
Tinner911
08-08-2005 09:09:44
I need a little help from all of you orange experts out there...
I went to look at a tractor this morning that was advertised as a WD45. But it has decals on it that just say WD. It looks like it was painted in the last 20 years and it could very well have the wrong decals. The number that I found on the back says WD 91106. According to the serial number list on this website it should be a WD. But, it has snap couplers, and the shifter rod comes up and bends to the left. Another AC man I know told me that the WD had a straight shifter rod, and only the latest WD's had snap couplers.
So..... 1) Am I looking at the right number on the tractor? This number that I found was on the rear about a foot below the seat and about a foot to the right. It was right below some sort of access plate on the rear end of the tractor. The access plate was on the top of the casting, the number was on the rear. The access plate had a hump in the middle like there must have been a gear or something right under it.
2) Could I have missed a number? The number says WD 91106 (I think) Could I have missed a 1 between the D and the 1? So it could be WD191106? That would make it a WD45. There is also a number on the left brake housing that is AM-3635-8. Does this tell me anything?
3) Are there any other disticnt differences between the WD and the WD45 that I should be able to find?
I think it's a pretty good bargain if I can figure out exactly what it is.
Thanks for your time!
Tinner911
08-08-2005 19:13:54
 Re: WD or WD45 in reply to Tinner911, 08-08-2005 09:09:44
Wow guys- Thanks for all the input. Lots of knowledge here. I went back to look at the tractor in person tonight. It DOES have the plate on the side of the engine, and it does NOT have the traction booster gauge, so I am 99% sure that it is just a WD. It does however have the "Power Crater" decal. I"m guessing that must have been stuck on there later.
So now that I know it is a WD, what do you guys think of the price? It leaks a fair amount of Hydraulic fluid from the belly and from the cylinder on the side that lifts the arms on the rear. Also, when the clutch is out, there is a kind or rattle that comes out of the hydaulic pump area when I have the lever in the lift position. It does not make the noise when the blade is sitting on the ground.
Thanks again guys, I hope I can help some of you out some day!
Farmered
08-08-2005 15:03:08
Power shift wheels didn't come out until the 45s, but they could have been changed also. Ed
DanD.
08-08-2005 17:16:07
 Re: WD or WD45 in reply to Farmered, 08-08-2005 15:03:08
Power shift wheels came on the WD's from the beginning in 1948. They also were on the CA's when they came out in 1950.
John (MO)
08-08-2005 10:12:45
The tractor is at least 50 years old, no telling how many parts have been changed. That could include the engine block and or the transmission. The serial number 91106 is for a 1951 WD, the serial number 191106 is for a 1955 WD45. As others have said, the WD block had the large removable plate on the side where the WD45 block did not. Many many WD motors were upgraded when overhauled to have the same bore and stroke as the WD45, so just because it might have a WD block does not mean it is not almost as strong as a WD45. I say almost, because I believe the WD45 used a little different carb and maybe a little different manifold also. These items were not so often changed at an overhaul as were the pistons and crank. The WD's made in the last year of production had the curved shifter and different gears just like were used on the WD45's when they came out. I believe the shifter stick it's self is interchangable, so it could be just the stick wore out and someone changed it. I'm not sure just when the pin hitch changed over to the snap coupler bell, but in my experience you seldom see a tractor or implement that still has the pin hitch, they were changed as all the later tractors used the snap coupler system. Price wise, WD45's are usually worth $200 to $500 more than WD if they were in the exact same condition. Here in MO, WD's start at around $600 and go to maybe $1200, where a WD45 will usually start at around $800 and a really really nice one might bring $2000.
ed (MD)
08-08-2005 14:36:22
 Re: WD or WD45 in reply to John (MO), 08-08-2005 10:12:45
the curved shifter is on the 1953 wd d(1st half year) and all wd 45's. the 45's have 6 digit serial #'s and is located on the back of rear to the left of the seat. 45's have a bigger carb and different manifold. and as the others said the wd has a plate on the right side with 6 bolts holding it on the engine. 45's will have a traction boster gauge just under the gas tank. the only thing i can say is in maryland and southern Pa. a nice wd goes for no more than 1500 and thats in really good shape. 45's have gone up to 4000 that i've seen at auctions. big difference in price and trying to get rid of it later.
Eldon (WA)
08-08-2005 12:13:07
John the shifter sticks will not interchange....the bottom ends are quite a bit different in length.....I tried it once.
John (MO)
08-08-2005 13:27:23
 Re: WD or WD45 in reply to Eldon (WA), 08-08-2005 12:13:07
Thanks Eldon that's really good information. I've never felt that it was a good idea to infre anything about the tractors by the shape of the shifter, but if they can't be interchanged, then it's helpful to know which shifter a tractor has.
Tinner911
08-08-2005 10:34:07
Wow- You guys are a wealth of information. I want to buy this tractor to plow snow in my driveway and to just have around as a utility tractor. I own 10 acres and I think it would do me fine. I was brought up on IH and I also own an M Farmall. My dad quit farming in 1962 and is a tried and true AC man. The WD45 was his all time favorite tractor. He is 85 years old now and I took him with me to look at it this morning. He got on to take it for a drive and he was grinning ear to ear when he came back. I guess bottom line is that if the two tractors are this similar that I can"t even tell them apart, does it really matter which I have?
This tractor has a rear blade and a loader with a snow bucket. The sheet metal is in great shape, except for the fenders. They are a little wrinkled (not to bad) and one is rusted some behind the heavy bracket that they are fastened to. It has 4 tires (13.6 - 28) that all look like brand new. Each rim is rusted around the valve stem some and there is probably a hole about the size of a nickle where the valve stem goes in. It ran and sounded great. The guy wants $1500 for it and didn"t sound like he really wanted to come down any.
wolfman
08-08-2005 17:18:14
 Re: WD or WD45 in reply to Tinner911, 08-08-2005 10:34:07
13.6-28's kind of gives it away as a straight WD. I think all true 45's had the 13 in rims and 14.9-28's. Check out the spark plug openings in the head-on the 45's, a big tall opening probably due to 4 1/2 stroke and crater pistons. Old WD's had shorter head ;4 in stroke and those small spark plug openings.
JMS/MN
08-09-2005 07:45:20
 Re: WD or WD45 in reply to wolfman, 08-08-2005 17:18:14
Standard rear tire on a WD was 11-28. (12.4-28) Optional was 12-28. (13.6-28). Standard on the WD45 was 12-28. Optional was 13-28. (14.9-28).
John (MO)
08-08-2005 13:32:35
With a loader and rear blade (AC snap coupler blades are pretty valuable), and 4 good tires, then I`d say $1500 isn't too bad. And, the smile on your dads face... priceless! Sounds like the rear rims may need some work, but a welder can patch them pretty easy. Having the tires removed and remounted could end up costing more than the rim repair. Let us know if you get it bought
Tinner911
08-08-2005 14:08:23
 Re: WD or WD45 in reply to John (MO), 08-08-2005 13:32:35
Priceless Indeed!
Now, the mystery continues as I have more information that conflicts with what I have learned here today.
I called the seller back to ask him about the engine block. He said that it does NOT have the removable plate by the distributor. So this should make it a WD45 engine, correct?
But, the serial number on the block is WD 339407 PA. Someone else mentioned that the serial number should be like 45-####### if it is a WD45 engine. Any ideas on this?
Thanks again, I'm sure glad I found this site today!!
John (MO)
08-08-2005 14:19:29
 Re: WD or WD45 in reply to Tinner911, 08-08-2005 14:08:23
You are in over my head now. If I had to guess, maybe a replacement block or a block from a combine or aux. power unit of some sort. I`m assuming it a gas engine and not a diesel, is that correct? You might also try the boys over at w w w.allischalmers. com
Tinner911
08-08-2005 14:28:55
 Re: WD or WD45 in reply to John (MO), 08-08-2005 14:19:29
Yep, it's gas.
Aaron SEIA
08-08-2005 09:27:21
The snap coupler stuff can be added to any WD, a tranny swap could have been done at some point (or a torch used to bend the shift rod). Check the distributor side of the engine, if there is a big plate bolted there, it"s a WD engine, if not, it"s a WD45 engine. In the grand scheme of things, 99% of the parts swap anyway, so there isn"t enough difference in a WD vs 45 to even worry about.
Aaron SEIA
CAL (KS)
08-08-2005 09:24:07
late model wd's had bent shift lever. check engine serial # if its a wd45 it will begin with 45-########## and will not have the removable plate behind the distributor on the block as the wd's do. also it very possible that it may have parts from both models as they are almost identical.
not an expert but have read enough post to know that is what everyone will tell you.
