'52 WD Bendix Drive
David in Mo
08-08-2005 08:04:10
The old WD had been running fine for 5 years but while the original starter spins fine, the bendix drive gear no longer seems to engage the flywheel. Teeth on flywheel look good and I purposely hand cranked it around for different starting spots. Even tried a different battery, 6 volt positive ground. Took the motor out to inspect the drive. The shaft, gear, and spring look okay. Any ideas?
old
08-08-2005 08:10:47
 Re: '52 WD Bendix Drive in reply to David in Mo, 08-08-2005 08:04:10
On starter drives even when they look good they can still be bad. If you where close enough to me I have a complete starter for a WD plus a lot of other parts. I'm at the lake of the ozarks.
