putting clutch in a wd45
dave in Mn
08-07-2005 20:03:09
To put a clutch in a wd45. Will I need to remove the radiator and steering u jount along side of the engine?It has a wide front so will I need to remove the Wide front too?
I would appreciate yor guidence.
Thanks
JMS/MN
08-08-2005 05:39:34
 Re: putting clutch in a wd45 in reply to dave in Mn , 08-07-2005 20:03:09
Like old said- but the steering box stays in place. Disconnect the u-joint, and pull the steering wheel to the rear to get a bit more room to work in. Also remove the bracket and spring on the cranking shaft at the rear of the steering box. Radiator is held in place with two half-inch bolts from the underside, inside the u-channel. Plywood laid across the frame makes a handy work platform for the engine if you don't have an engine stand.
old
08-07-2005 21:11:44
Just a guess here. But I know in a WD you have to pull the rad and the steering arm to do so, so I would think you would also have to on a WD45
