Pedestal on a C and Timing Gear Cover
Tim in SE WI
08-07-2005 19:49:01
I"ve removed the pedestal from my C,now how do I remove the pinion gear from the spindle shaft? The gear pullers I"ve tried keep slipping off because of the bevel on the bottom of the pinion gear. Do I need a special puller?
While I"m at it should I replace the timing gear cover? I really dont want to have remove everything again to get to the timing cover. What do you think? Thanks for any advice!
Tim
Dick L
08-08-2005 06:09:29
 Re: Pedestal on a C and Timing Gear Cover in reply to Tim in SE WI, 08-07-2005 19:49:01
After the capscrew is removed from the top, you can press the shaft out the bottom. Check for shims under the gear and dont have a toe under the shaft when pressing it out. Once the gear is clear of the shaft it will fall freely. Don"t ask!
