WD Final Drive Pan Gaskets
Utah Jim
08-04-2005 18:41:51
I hava a 49 Allis WD and would like to find 2 new
WD final Drive Pan Gaskets. Any help or suggestions would be appreciated.
Thanks Utah Jim
Utah Jim
08-05-2005 06:37:56
 Re: WD Final Drive Pan Gaskets in reply to Utah Jim, 08-04-2005 18:41:51
Thanks to all for your replys. I sure appreciate your quick responces.
Utah Jim
Gatz
08-04-2005 18:52:22
Just buy some 1/16 cork gasket material at auto-parts store. (And some adhesive... 3M Auto Trim Adhesive works great...comes in a tube)
Lay the cover over it, trace the outside and mark the holes. You can buy a set of cheap import hole punches for less than $10, or use the peen end of a small hammer and tap lightly when holding on the cover to cut the hole circles out.
Figure the border width from the cavity in the pan and layout lines, cut out with utility knife.
Gatz
Phill Snartland
08-05-2005 04:57:26
 Re: WD Final Drive Pan Gaskets in reply to Gatz, 08-04-2005 18:52:22
Or, you could just buy replacement gaskets from Sandy Lake Implement in Sandy Lake, PA. They keep them and lots of other parts for the older Allis tractors in stock. Brenda in Parts is a great help and Bill in Service has given me lots of advice as I've been restoring my WD-45.
Phill
