wd charging system
Scott in Illino
08-04-2005 08:30:25
Just got a 51 wd which the gen was not working. I put another one in and it works, but apparently the 3 pos light switch is no good because I am only getting one rate of charge which is about 15 amps at full throttle. Can you still get those light/charge switches or can you go to a voltage regulator or some other setup to control rate of charge? Any ideas would be appreciated. Thanks,Scott
Ted Seifert
08-06-2005 11:02:33
 Re: wd charging system in reply to Scott in Illinois, 08-04-2005 08:30:25
The wire wound resistor controls the low charge rate. It is 3 ohms 25 watts. Check to see if the wire is broken.
mike luce
03-13-2006 08:41:40
 Re: wd charging system in reply to Ted Seifert, 08-06-2005 11:02:33
163 continental flat head. converted to altenator with electronic distributor. the switch was on the tractor was not running, then the wire that goes to the ammeter had a melt down, after the wires were seperated i could not tind any obovious problems or shorts, any suggestions on probable causes, thanks mike
scott in illinois
08-07-2005 18:21:12
Thanks to all for your excellent responses. It has been extremely helpful and it is nice to know that help is just a click away. Thanks again,Scott
David in Mo
08-05-2005 12:08:08
I dissassembled mine, cleaned it, and put it back together, and it's been working fine for the last 4 years..... ..... ..
Steve in N.J.
08-05-2005 03:44:07
Scott,
We have the original OEM 3 position switch on an exchange program all rebuilt/restored and ready to install. Available with or without the rod and knob. Drop us a line if interested...
Steve@B&B
[email protected]
Brian F. Williams
08-04-2005 09:33:02
I had a Minnie Moe U that had the 3 brush generator. I ended up putting a voltage regulator on it and workrd fine. I did however see somewhere on the internet someone has the switches. If i remember correctly they were pretty expensive. If I remember they were $75 - $90 for the switch. Hope this helps.
steve(ill)
08-04-2005 19:30:04
 Re: wd charging system in reply to Brian F. Williams, 08-04-2005 09:33:02
easy way is to replace the switch. 6 volt regulator can also be installed. basically all the switch is, is a llight switch plus a big resistor connected to ground. ---the "F" terminal on the generator must be grounded to get a charge. if it is shorted directly to ground you get 15 amps. if it is grounded thru the resistor, you get a "loss" and the generator output is more like 3-4 amps. the light switch puts the resistor in circuit when the lights are off and grounds the F wire directly (no resistor) when the lights are on. you can alos use a toggle switch and turn on for an hour each time you run the tractor so the battery stays charged, but that is the manual way to do it.
