WD 45 Power steering
rrh
08-02-2005 14:04:41
Would like 2 put power steering on my wd45, has a after market wfe and a 8n ford frontend loader on it, any help on how 2 mount am pump, and some way 4 power steer cyl. it. Thanks
allis45
08-04-2005 18:52:55
 Re: WD 45 Power steering in reply to rrh, 08-02-2005 14:04:41
I have a wd 45 diesel with a charlynn torque generator that works very well. I am powering it with a pump that is ran off of the back of the electrical generator.I found the delco generator and the power steering pump on older clark fork truck, it is a self contained unit with the pump mounted inside of a quart sized resevoir.
James Johnson
08-03-2005 07:08:17
I have the unit Butch is talking about on a W D It hasn't been used for 20 years. If you want to pay the shipping, I'll send it to you and if it works you can send me a "donation."
dave in Mn
08-03-2005 09:56:14
 Re: WD 45 Power steering in reply to James Johnson, 08-03-2005 07:08:17
Hi James,
If he is not interestet in the unit I certainly would be. Just let me know what you are thinking.
best regards
Dave
Butch(OH)
08-02-2005 15:17:26
The A-C factory and popular Charr-Lynn power steering setups did not use cylinders, they use what is called a torque generator that mounts on the steering shaft usualy under the gastank. The Charr-Lynn unit is still availible from Eaton/Force America. Here is a link to the Surplus center that should take you right to the page with the torque generators. Call them for pump recomendations, they are very helpful. Years ago we used to use Ford power steering pumps, 1960s stuff, may be others that work, GM will not, again talking 60s stuff. The pump will fit up umder the hood, has to be driven by the fan belt, you place it where the belt will line up and build brackets from there. Complete units, factory A-C and other wise show up on Ebay quite often. They are pricey but so is new Eaon unit and pump.
