WD-45 Wiring
Phill Snartland
08-01-2005 09:09:10
I neglected to make a sketch of hte wiring on my WD-45 when I took it apart for the restoration, now I'm stuck on one question. I'm running a POSITIVE ground circuit, and I need to know which terminal on the coil (+ or -) to connect to the distributor. None of the sketches in the sevice manual tell which way it should be, and Duey's sketches are all for NEGATIVE ground circuits. Duey's sketches show connecting the - terminal of the coil to the distributor in a NEGATIVE ground circuit. Should this be changed for a POSITIVE ground circuit?
Thanks for the help!
Phill
Steve in N.J.
08-05-2005 03:48:14
 Re: WD-45 Wiring in reply to Phill Snartland, 08-01-2005 09:09:10
Phill,
We have a complete wiring system kit for your WD if you want to renew the system. Drop us a line if interested....
Steve@B&B
steve(ill)
08-01-2005 19:58:48
yes, the "ground" end goes toward the distributor. negative ground is - to the point nad positive ground is + to the point.
