A/C G Clutch
Jeff WIll
07-27-2005 05:21:04
When I put away my G last year the clutch was working fine, now the clutch will not disengage the engine from the transmission. The only way to get the tractor in and out of gear is to force it. I do not have a lot of experience with this tractor. I did notice a connecting rod that goes from the foot pedal though a housing and then has a nut on the end of it. I tried to adjust the nut thinking that this may adjust the clutch travel but it did not help. Any thoughts? Thank you.
jason(ma)
07-27-2005 18:44:03
 Re: A/C G Clutch in reply to Jeff WIll, 07-27-2005 05:21:04
had to dig a mouse nest out of mine when I bought it. I'd pull the starter and see if somethings in there.
jps575757
07-27-2005 08:59:44
The G manual advises to use clutch pedal lock (at pedal) to prevent this during storage. When mine did this I started it in gear and drove it. It broke loose in short time. NOTE:This could be dangerous for the inexperienced.
Gatz
07-27-2005 05:46:51
The clutch plate is probably just sticking to the flywheel surface or pressure plate from non-use. Don't force it into gear untill it's working correctly.
Try putting it in high (with engine off), push down on pedal, and rock back and forth a few times.
If it was working b/4, it shouldn't need any adjustment.
Jeff Will
07-28-2005 04:55:56
 Re: A/C G Clutch in reply to Gatz, 07-27-2005 05:46:51
Did just like you said and the clutch came free. I guess I will have to lock down the clutch pedal from now on durning storage.
Thank you.
