Allis B Cane tractor with D series engine
LeRoy Price
07-24-2005 06:25:38
Guys,
I found a 1955 Allis B Cane Special on the ineternet which I eventually bought. I now have it closer to me and we have found that the engine has been changed and it seems that its from a D10, D12 or D14 since the casting number is AM 4339-14. I saw a 1956 Allis B block which had AM4033-1 on it so I"m thinking it should be close to that number if not the same.
Question is since I already have $1800 into this thing is to either restore it with the existing engine or go original. Not sure what leaving the existing engine would do to a selling price. Not sure if Allis collectors are as picky as some JD collectors.
Can anyone offer a suggestion on what they would do?
LeRoy
steve(ill)
07-24-2005 18:56:37
 Re: Allis B Cane tractor with D series engine in reply to LeRoy Price, 07-24-2005 06:25:38
the 149 cid motor you have is more expensive than the 125 CE motor. i would guess you would not have a problem trading someone if you are interested in installing a CE motor. The CANE would be more collectable with the CE motor. THe usefullness of a CANE tractor on a day to day basis i would think is limited. more of a collector- show item.
LeRoy Price
07-24-2005 19:12:30
 Re: Allis B Cane tractor with D series engine in reply to steve(ill), 07-24-2005 18:56:37
Steve,
Thanks for the note and I see you are in a couple of forums.
Yes, I'll probably go with the CE engine just because its a Cane. If it wasn't I'd keep what I got. I did find a CE engine thats close. Its suppose to have been overhauled and then let sit. Hopefully its fine. The D series engine would be taken in trade if the engine is good. But I'm getting 2 prices. Not sure how much a CE would run price wise. I do know that the D series engine I have is loose and was running prior to me buying it. The tractor had a starter issue thats fixed now but I haven't tried to start it because the carb needs attention.
LeRoy
