Converting to a paper air filter
Tom Dooley
07-21-2005 09:06:21
I thought I would replace my oilbath air cleaner on my 1941 Allis C with some kind of a paper filter.Instead of reinventing "the wheel", I thought some one out there might have a source for this kind of a set up. I do not use this tractor for field work, only parades and pulling.Thanks Tom
magnut25
08-04-2005 15:46:12
 Re: Converting to a paper air filter in reply to Tom Dooley, 07-21-2005 09:06:21
I can't remember where I read this but someone said that they put a K&N filter on a WD-45. It said that it fit inside of the original housing and no one was the wiser. Might be something to check in to.
Eldon (WA)
07-21-2005 22:02:42
I've got a C that has a car air filter housing adapted to fit on top of the original cleaner pipe....don't look too bad, and filters are cheap.
Dean Barker
07-21-2005 21:36:00
Filter tests show that oil bath filters take out about 94% of the dirt while paper filters take out 99.99% of the dirt. I have seen an advertisement where they take your old oil bath and fit a paper element inside so the looks stay the same. Sorry I can't tell you who does this.
Wild Bill
07-22-2005 06:48:38
 Re: Converting to a paper air filter in reply to Dean Barker, 07-21-2005 21:36:00
47% percent of statistics are wrong, the other 53% are screwed up!
JMS/MN
07-22-2005 07:51:18
 Re: Converting to a paper air filter in reply to Wild Bill, 07-22-2005 06:48:38
64% of statistics are made up on the spot- like I just did!
Dieselrider
07-22-2005 05:01:13
I'll bet the people saying this are selling paper filters.
Tom Dooley
07-21-2005 14:57:27
Well, I certainly have some pondering to do on this.I looked at a sponge filter that is oiled instead of a paper filter, but like it has been said, the price might not make that set up worth while. Thanks for the input. Tom
w.burrow
07-21-2005 14:26:47
don't change your oil bath type filter, they work very well. if cleaned and serviced properly they will trap more dust than a paper one
souNdguy
07-21-2005 11:28:59
You'd actually be taking a step backwards by doin this.. the oil bath / mesh filter is more efficient than the paper pleated filters..
Soundguy
mj
08-11-2005 23:26:06
 Re: Converting to a paper air filter in reply to souNdguy, 07-21-2005 11:28:59
EXCEPT at 20 below zero.
souNdguy
08-12-2005 10:54:13
 Re: Converting to a paper air filter in reply to mj, 08-11-2005 23:26:06
At -20.. I'd be inside having some coffee!
Soundguy
DanD.
07-21-2005 09:28:04
Just my opinion, but if you only use the tractor for parades and pulling, then don"t ruin the looks...just use the filter that"s been on it for the last 64 years. DOn"t waste the money.
old
07-21-2005 09:13:21
If your not to worryed about looks you can put on a hi pro filter that is made for a motorcycle or ones they have at auto parts stores. it would just clamp on to the end of the carb.
