Holes on the bottom of the WD rear dif
Chad B.
07-20-2005 06:15:08
I'm crawling around this WD I came into and trying to figure everything out. On the bottom side of the rear differential and on either side of the drawbar bracket there are two holes - roughly as big around as a soup can. What are these for? Should they be capped or plugged?
wdtom
07-21-2005 18:16:55
 Re: Holes on the bottom of the WD rear dif in reply to Chad B., 07-20-2005 06:15:08
AC put these holes in many of their tractors so mice could get in and build mouse condos. If they build a big one you can get enough shi& in there to cause friction and smoke will start comming out of the brake housing. I always thought I would put some hardware or screen cloth over these holes to keep the mice out.
Jerry Coulter
07-20-2005 08:35:42
Leave them open. They are vent/access holes for the brakes.
