Which is it
R.D. Hoover
07-19-2005 18:29:22
I just got a (what seems to be a WD45)from a friend. However, I have a 55 and this one is different. First the gear shift is straight, it has a snap couple, the seat does'nt flip over like the one on my 55 does. It has a decal on the raditor that says WD45. BUT the serial number has been stamped over once right side up, and once upside down. Is this a WD or a WD45. Thanks.
John (MO)
07-20-2005 06:17:37
 Re: Which is it in reply to R.D. Hoover, 07-19-2005 18:29:22
All 45's came from the factory with curved shifters, of course that was almost 50 years ago, no telling what one of them has by now. Also 45's came from the factory with solid blocks that did not have a plate bolted to the side. Again, no telling what engine is in a tractor by now. An many many straight WD's have had overhauls and 45 parts installed to boost their hp to that of a 45. Now why the serial number is stamped twice, once upside down, that's a real strange one. You know if it were a coin with the date stamped on it like that, you might have quite a nest egg, but I'm not sure if that's the case with a tractor.
chalmersbob
07-19-2005 18:59:38
all wd45's had a curved shifter. must be a straight wd. look below the sparkplugs. if it has a bolt on plate, it is a wd
