UPDATE (can't re-align gears yet...) [help]
Will Herring
07-17-2005 18:54:19
I'd prefer to not have to remove the gear housing if I didn't have to... All I did so far was pull the snap ring and the two washers. The stick pulled straight up and out with some force; and the square pin never even came out. It's still in there.
I can see that the reverse gear is indeed misaligned, but the tractor was parked on a bind and wouldn't release the gear. But by the time I backed it to the house after failing to move it, it was nightfall, so I will try again tomorrow. If I try again tomorrow and the gear releases - and I can reseat the assembly - I'm home free.
If it won't release, is there some way I can "help" it free? This is what I see when I look into the tower the shifter was in with a flashlight: (image size is like 5 KB, it's black n' white)
Link
What bothers me is that little black box I drew in there is a piece of metal... And I assume it's supposed to be there. I assume only though. I don't know if it needs to be pressed down and then I need to pry the gear over or what.
~Will
JMS/MN
07-17-2005 23:32:24
 Re: UPDATE (can't re-align gears yet...) [help] in reply to Will Herring, 07-17-2005 18:54:19
You mention backing it to the house- that means it is not stuck in two gears- it is in reverse and the shifter is out of the forks. My previous advice still applies- you need only to remove the shifter and align the shift forks. Granted, the bottom of the shifter still needs to be rebuilt, and maybe the top of each shift fork needs to be built up. But at this stage you do not need to remove the battery, battery box, cables, steering wheel support, shifting tower, etc. It is much quicker to remove the shifter and align the forks. You mention a piece of metal- there is a small piece of metal inside the tranny, I think it is on a shifter fork, but without my manual here I cannot ID it or tell you where it is or its function- but I know that it belongs there. I tried twice to access your link but it would not show up. The curve in the shift lever is not the problem- the WD45 was easier to shift than the WD. The problem is likely to be on the bottom of the shifter- and if you rebuild it by welding and grinding- the angle of the wedge at the bottom is NOT parallel to the angle of the top of the shift lever. Compare it to a new lever.
Will Herring
07-18-2005 08:10:33
 Re: UPDATE (can't re-align gears yet...) [help] in reply to JMS/MN, 07-17-2005 23:32:24
I'll try again tonight after work to see if I can get the forks to realign. Reverse was stuck (tractor was parked at bad angle) where it was originally, so maybe I'll have better luck tonight.
I'll report back later. Glad to know that little metal knob is SUPPOSED to be there though (and that it's not a piece of the shifter).
~Will
