WD versus WD45 Engine
Ron Nickels
07-17-2005 17:05:26
I have a 51' WD and the engine is in pretty bad shape, needs sleeves, pistons and one rod bent. The crank also needs turning. The block and camshaft are good and the head has just been rebuilt. I have access to a WD45 engine. Which parts will interchange from WD 45 to WD.?
UUSEE
07-21-2005 05:48:40
 Re: WD versus WD45 Engine in reply to Ron Nickels, 07-17-2005 17:05:26
You can use the pistons also but the compression will be up there ,too high for regular gas.Power is good though!!
DanD.
07-21-2005 11:07:02
 Re: WD versus WD45 Engine in reply to UUSEE, 07-21-2005 05:48:40
Actually, using the WD45 pistons in a WD will result in a very low compression ratio and poor performance. The other way around however(if you use WD pistons in a WD 45 engine) you'll have a very high compression ratio. This is due to the 1/2" longer stroke in the WD45.
wdtom
07-17-2005 17:28:44
I believe almost everything will interchange. If you use the 45 crank you need to use 45 pistons too. The 45 oil pump is higher output too I think which is good. The head is a little taller too on later WD and all 45 engines. Maybe the cam is a little hotter too?
