good the bad and the ugly
brian nees
07-17-2005 09:21:00
can any one tell me all the goood things abiut a 7060 and all the bad thing to look at on a 7060
TomF
07-18-2005 20:23:43
 Re: good the bad and the ugly in reply to brian nees, 07-17-2005 09:21:00
For the most part, the 7060 is a good dependable tractor. We have one we bought new 28 years ago. Was our "big hoss" for a good many years. Now just use it for lighter work--not many hours per year. Capable of putting out a lot of power, if you're inclined to tinker with the pump a little. Torque limiter may cause problems under those conditions, though. Never had any tranny or rear-end problems. Most of them smoke like steam engines. Nature of the beast. If it's equipped with standard AC sleeves & pistons, it won't start worth a d--n in cold weather, unless you use block heater. Wouldn't recommend using ether on them. Some of them sustained damage in #3&4 cylinders due to the way the ether injector is positioned in the intake. If it happens to be rebuilt with M&W sleeves & pistons, it will start much better in cold weather. Will also run quieter--much less diesel knock & rattle. Not the greatest cab in the world, but servicable. All in all, a pretty good ol' hoss.
Hope this helps.
