Allis B strange exhaust
Grennie
07-16-2005 14:05:09
My newly aquired B has a siamese exhaust (home made?) which splits into twin pipes just as it comes through the top tin. Needless to say getting the top tin off is impossible as the hole in the tin will not allow the twin pipes through it. How is the lower single exhaust pipe attached to the manifold ? If I can remove the whole pipe I will throw the siamese setup away and fit a standard exhaust. Thanks
chalmersbob
07-16-2005 18:30:17
 Re: Allis B strange exhaust in reply to Grennie, 07-16-2005 14:05:09
exhaust is mounted with a single bolt thru the manifold and the pipe usually has a slot in it that slides oved the bolt. can be tough to loosen the bolt when very rusted. once loose you should bo able to twist the pipe and work out. lol BOB
Grennie
07-17-2005 00:46:05
 Re: Allis B strange exhaust in reply to chalmersbob, 07-16-2005 18:30:17
Ahh .. there is a hole there but no bolt, thats what was confusing me. Many thanks.
CHALMERSBOB
07-17-2005 18:49:48
 Re: Allis B strange exhaust in reply to Grennie, 07-17-2005 00:46:05
ON MY 1940 B, THE MANIFOLD IS ALSO THREADED INSIDE FOR 1 1/2" PIPE THREAD. I DON'T KNOW WHAT YEAR YOU HAVE OR IF IT HAS THE ORIGINAL MANIFOLD, BUT IT COULD ALSO BE THREADED. LOL BOB P.S. I LIKED THE WAY YOU FREED UP THE ENGINE, HEAT WAS A BIG HELP.
Grennie
07-27-2005 01:31:30
 Re: Allis B strange exhaust in reply to CHALMERSBOB, 07-17-2005 18:49:48
I have bought a new under hood exhaust box which has solved all the problems. Thanks for your help.
