old allis engine what year is it
Bryan Davis
07-16-2005 11:30:01
i have pick up a old allis engine it's off a sawmill. there is a allis tag on the cluch case and the # is PU13339W AND on the left side of the engine there is a# U3016-25. if any one can help me with what year it is it would help me alot thank's
Tramway Guy
07-17-2005 18:25:39
 Re: old allis engine what year is it in reply to Bryan Davis, 07-16-2005 11:30:01
I think the "PU" refers to Power unit, and the "W" at the end refers to the series. The casting number for WC"s and WD"s started with "U" also. I would guess it is a 201 cubic inch engine, since it has a magneto. It probably also has the bolted plate on the magneto side also, right? If so, it might fit in a D17, but performance would be only about half to 2/3 what a D17 would be.
Bryan Davis
07-17-2005 19:41:29
 Re: old allis engine what year is it in reply to Tramway Guy, 07-17-2005 18:25:39
thank you tramway guy, you have help me alot.i think it would be better to rebuild the engine out of the d-17, or find one for a d-17
CHALMERSBOB
07-16-2005 18:40:28
I BELIEVE YOU HAVE A "U" POWER UNIT. THE "U" TRACTOR WAS BUILT FROM 1929 UNTIL 1953. THER ISN'T ANY REGISTRY FOR "U" ENGINE SERIAL #s LIKE THERE IS FOR TRACTORS. A "U" TRACTOR WITH A SIMILAR SERIAL # WOULD HAVE BEEN BUILT IN 1930. THIS MAY OR MAY NOT BE A CLUE TO THE YEAR OF YOUR ENGINE. LOL BOB
BryanDavis
07-17-2005 08:26:54
 Re: old allis engine what year is it in reply to CHALMERSBOB, 07-16-2005 18:40:28
thanks bob for your info.do you know if it would fit in a 1967 d-17 s-iv, they look the same. the u power unit has a mag and the d-17 has a dist, but it looks like they will change out? thanks again.
