WD final drive fill location
Gary in MO
07-15-2005 19:36:40
I am needing someone to tell me where to top off the fluid level in my WD's final drives. Thanks,
Gary
Texas Denny
07-16-2005 15:37:57
 Re: WD final drive fill location in reply to Gary in MO, 07-15-2005 19:36:40
Terry is correct. I have a quart sqeeze bottle that I fill with the heaviest transmission oil I can find. It doesn't take much - one quart.
Terry(GA)
07-16-2005 06:42:11
About 1/3 of the way up from the bottom of each is a small plug.You can remove it and add there,but its a slow go.If you plan on changing it you will have remove all the bolts from the final drive cover and drop it down.Crawl under the tractor and take a look,and you should see what I am talking about.Good luck!
Gary in MO
07-17-2005 20:40:20
 Re: WD final drive fill location in reply to Terry(GA), 07-16-2005 06:42:11
Thanks guys,
It took a little bit but I found those plugs. You sure do have to be on the ground to see them. Fortunately mine weren't low at all. I, too, have a squeeze bottle I was going to use for this, but didn't need to. I wonder, has anyone ever drilled and tapped a drain in the final drive pans? Sure seems like it would make this job easier and maybe less messy. What do you think?
Brian G. NY
07-18-2005 05:32:07
 Re: WD final drive fill location in reply to Gary in MO, 07-17-2005 20:40:20
I've heard of people going to the trouble of installing drain plugs in the bottom of those pans. It sure would make it easier to "drain twice a year" like the manual calls for. However, very, very few people routinly change the final drive oil so it's probably a good idea to pull the pans when doing so to remove any sludge buildup.
